It is currently Nov Wed 04, 2026 6:03 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
PostPosted: Dec Thu 07, 2006 9:49 pm
i need a few pics of window nets. i need to look at different ways to mount them. preferably the upper area above the window. thanks
PostPosted: Dec Tue 12, 2006 9:04 am
too many to choose from here, stop posting all the pictures guys :lol:
PostPosted: Dec Tue 12, 2006 9:20 am
We just use a seatbelt buckle. Weld the male part to the bar ( be careful to put it in a position so that you don't cut your head open getting in and out) . Weld the female end to a rod that runs through the net. Simple and user friendly. :)
PostPosted: Dec Tue 12, 2006 9:29 am
on the upper rod, on the opposite end of the buckle, how do you attach that end of the rod? does it come out or pivot ?
PostPosted: Dec Tue 12, 2006 9:56 am
i was thinking something like this.
Mine pivots....
PostPosted: Dec Tue 12, 2006 9:58 am
Were you just thinking of inserting the rod into the hole in the plate??? Good thing Dogg isn't here to take this thread to a bad place.....
PostPosted: Dec Tue 12, 2006 10:18 am
kevin, the top has one buckle end and one pivot end? the bottom stays attached at both points, correct?
PostPosted: Dec Tue 12, 2006 10:59 am
I have a clevis at the top rear to pivot that says attached and a pin and clevis that secures the top front. Both bottom attachmetns stay attached. The front of the top bar will rotate down and rearward out of the way...
PostPosted: Dec Tue 12, 2006 11:06 am
thanks :D
PostPosted: Dec Tue 12, 2006 11:16 am
:wink:
PostPosted: Dec Tue 12, 2006 12:45 pm
that pivot is a great idea. My buddies car has a hole that the rod slides into & then it snaps in with the buckle. It works great, but........ he cant do it by himself while he is buckled in. it takes a LONG time for him to get it done by himself.
PostPosted: Dec Tue 12, 2006 12:49 pm
does he wear arm restraints or somthing?
PostPosted: Dec Tue 12, 2006 1:17 pm
It is real nice knowing it is where it is supposed to be when I grab for it....
PostPosted: Dec Tue 12, 2006 1:19 pm
No, its just where it sits with the way the roll bar crosses his shoulder & the seat that he has & the way that the floor board scoots it down under the seat that makes it a PITB. its REAL easy for me to get to it from outside the car, but when your in it & buckled in, its difficult.
Users browsing this forum: No registered users and 35 guests
