It is currently Nov Thu 05, 2026 5:23 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Axle installation
PostPosted: Sep Wed 13, 2006 8:45 am
Well I started putting my 9" together last night, got the center section in and 1 axle inand secrued with no problem.
Then I went to the other side to install the axle and I can only get it in to where the bearings are about 1/2" away from the race and it seems like thats as far as it wants to go. We checked the splines on the axle and the spool and see no interference.
Anyone have any ideas I can try
Moser 35 spline axles
Summers Brothers Spool
Thanks for the help
PostPosted: Sep Wed 13, 2006 9:00 am
First I would double check by pulling the pig out and then install that axle into the splines. If it goes in then use a big hammer and a block of wood...... Some of them are stubborn Phil... Does it go in to where the o-ring is or approximately that deep???? If so, install the retaining bracket, and bolts and nuts and snug them. Then take a block of wood and lay it across the studs and give it a wack or 2... Then check to see if the nuts and bolts are loose to see if there is anymore engagement. If so snug the bolts again and then wack it again until fully engaged....
PostPosted: Sep Wed 13, 2006 9:11 am
You did check for proper length right????
PostPosted: Sep Wed 13, 2006 9:12 am
I agree with Kevin. Also check and make sure there isn't any paint or a burr where the bearing seats . Be sure and use some Vasiline or other lube on the orings. They can roll out and get cut when your installing the axles. If that happens you will have a leak.
PostPosted: Sep Wed 13, 2006 9:17 am
Not trying to be insulting, but you are putting them in the right side ? there should be about an inch difference side to side.
PostPosted: Sep Wed 13, 2006 9:26 am
Mine is allot more than an inch..... And yes, I am still talking about the axles..... :roll:
PostPosted: Sep Wed 13, 2006 9:29 am
Not taken that way at all Rick, yes I have the short axle on the short side and thats the one that we had no problem with, we being Jim Gorski and myself. We took the axle out and check it then reinstalled it and used a 3 pound hammer and it doesnt move from what I can tell. but I will pull the pig and see whats going on
Thank s guys
PostPosted: Sep Wed 13, 2006 9:47 am
i was wondering about the bearing too, if the surface had any imperfection in it
PostPosted: Sep Wed 13, 2006 10:56 am
My bad, I just realized after going over what I did that I put the short axle on the drivers side (left) when it should have been the LONG axle on the drivers side
:oops: thats what I get for trying to rush and get the rear end in the car last night late. Shame on me
PostPosted: Sep Wed 13, 2006 12:38 pm
Well that's good news....
Carry on.....
PostPosted: Nov Fri 03, 2006 10:14 am
Well,
we found out that the splines were not long enough for the spool. Had to have the axles re-splined a little longer. Mis-match in parts !!!!!
JAG Enterprises Racing & Fab.
1984 Mustang GT
342ci N/A - 10.71 @ 126
1/8 mile of 6.74 @ 101
PostPosted: Nov Fri 03, 2006 10:38 am
I wasn't aware that was something that could be done??? A typical axle I thought was thick in diameter in the area of the spline???? Was there enough thick diameter length to lengthen the spline???
PostPosted: Nov Fri 03, 2006 10:41 am
i was about to ask about that myself. im going to narrow the rear on my car about 2" on each side. and i was wondering if i could get my axles resplined to accomodate the narrowed housing.
PostPosted: Nov Fri 03, 2006 10:49 am
There typicaly isn't that much room to change the axle.. If I am correct, they must have been real close to the axle fitting?????
PostPosted: Nov Fri 03, 2006 10:52 am
It depends on who makes the axles. Some all the same diameter the whole length.
Users browsing this forum: No registered users and 128 guests
