It is currently Nov Fri 06, 2026 7:46 am
Post new topic Reply to topic  [ 13 posts ]
 Post subject: cage certification
PostPosted: Jun Mon 19, 2006 9:51 pm
how fast can you go with a mild steel cage?? not that im fast, just curious.
PostPosted: Jun Mon 19, 2006 11:14 pm
7.50 is the limit for mild steel.
PostPosted: Jun Tue 20, 2006 6:54 am
I think it might be 8.50 Rick... hmmmmmm...
PostPosted: Jun Tue 20, 2006 6:58 am
25.5 certification can be mild steel or moly steel. If your not at that level of certification, then it's 8.50. The basic upgade includes "X" the door bars, funny car cage, larger tube diameter behind the seats, gussets on the intersecting corners and a couple bars under the driver, one under the seat and one under your feet.
PostPosted: Jun Tue 20, 2006 7:50 am
where could i get more information on a 25.5 cage????
could i convert my 10 point cage into that??
thanks
PostPosted: Jun Tue 20, 2006 8:26 am
thanks
Anything can be updated. I used to have the 25.5 spec, but I gave it away. It costs money to order the spec. You can find info at:
http://www.sfifoundation.com/
PostPosted: Jun Tue 20, 2006 8:28 am
cool, thanks dogg.
PostPosted: Jun Tue 20, 2006 9:15 am
Stock tranny cross member can't be used neither, I just remembered that.
PostPosted: Jun Thu 22, 2006 1:31 pm
25.5 - Full Bodied Car Stock or Modified/OEM Floorpan and Firewall with OEM Frame or Uni-Body Construction – 7.50 to 8.49 Seconds; 3,600 lbs. Maximum
i didnt see anything about going slower than 8.49 though. i just want to make sure i order the right one.
PostPosted: Jun Thu 22, 2006 1:49 pm
i have nothing to contribute on the cage certification question.
Just wanted to say hey! Hope you are having a good day! :D
PostPosted: Jun Thu 22, 2006 2:01 pm
PostPosted: Jun Fri 23, 2006 10:30 am
what now dogg?
PostPosted: Jun Tue 27, 2006 10:39 am
Slower than 8.49 you can just use the specs in the NHRA OR IHRA rule book. 8)
Users browsing this forum: No registered users and 23 guests
