It is currently Nov Thu 05, 2026 3:04 pm
 Post subject: Well....
PostPosted: Mar Thu 16, 2006 8:45 am
Since you guys know your big block stuff I figured I would ask you guys
I plan on running a turbo and I was just wondering how much boost/power would the stock rods and crank in a 454 hold up too?
I plan on running the stock oval port cast iron heads with bigger valves and I was just wondering what would be a good compression to run, it will be a street car so it needs to run on pump gas (dont mind paying for the more expensive stuff) but I dont wanna run too low of a compression so it dosent have any grunt in the time it takes for the turbo to spool up, so if you guys have any tips or info let me know Thanks
PostPosted: Mar Thu 16, 2006 9:22 am
I'm not a turbo guy but I would think as far as the rods go if they have the good bolts, they should be able to take what you could give it for street use....
PostPosted: Mar Thu 16, 2006 9:39 am
Thanks
Do you think the crank will be ok?
PostPosted: Mar Thu 16, 2006 11:05 am
I would think the rods would give before the crank. If you have your clearances right, and enough oil you should be ok
PostPosted: Mar Thu 16, 2006 12:00 pm
Is the crank forged???
PostPosted: Mar Fri 17, 2006 1:50 am
I think its a cast crank
Any ideas on a good compression ratio to run?
Thanks guys
PostPosted: Mar Fri 17, 2006 9:30 am
You might want to rethink that crank......
PostPosted: Mar Fri 17, 2006 10:40 am
Ok thanks Kevin I will look into a forged one and see if my tight budget will allow for one :cry:
PostPosted: Mar Fri 17, 2006 11:28 am
Well i looked on Summit and found a Eagle crank and some rods that will hold 700hp for about 625$ this way I wont have to worry about risking used rods, but does that seem like a good price or does someone know of a place that may be alittle bit cheaper? Thanks
Users browsing this forum: No registered users and 23 guests
