It is currently Nov Sun 15, 2026 2:36 am
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
 Post subject: Volts to ignition ??
PostPosted: Jan Thu 08, 2004 8:40 am
Nice Web site! and a fast car to go with it.My question is that i have done 22 passes now. And have tried changing timing,jets,and still runs the same mph 142-144, the car even runs same mph hot day to mild night.Is this a sign of a ignition problem. I was thinking of running 16 volts to my holley pro strip annilator. car specs are 3400 lbs with pro 1 355cc. headed 555bbc with 900 plus hp. The car runs clean but just cant get the car to go 150 mph which is what i thought it would run easly. Any ideas
PostPosted: Jan Thu 08, 2004 9:01 am
Could you give me some increments??? 60', 1/8 mile et and mph, 1/4 mile et and mph. And any others that may be on the ticket.
PostPosted: Jan Thu 08, 2004 10:32 pm
Some nitrous would help........... :twisted: :twisted:
 Post subject: Re-ignition?
PostPosted: Jan Thu 08, 2004 11:36 pm
Okay here is the time sheet 60ft-1.43,330ft-3.95,660ft6.07,mph115.66,1000ft7.91,ET-9.47@143.83mph.I now the 60ft times are not flash,but the car is a factory four link with 10.5x28 MT slicks,at this stage iam getting beter 60ft without trans brake,next time out i will try the stiff side wall and trans brake and maybe get in the 1.3 60ft zone.I would have thought that the 60 ft times would have not hurt the mph,as wheel spin is only in the first 30ft on a good run.What would a typical 900hp 555 run in a 3400lbs car?
 Post subject: Re: Re-ignition?
PostPosted: Jan Fri 09, 2004 12:06 am
according to textbook physics (no slip or friction), you'd run 9 flat.
http://www.bbnovaracing.com/calchp.php? ... 400&et=9.3
Real life is probably closer to 9.3-9.5
I'd say yer right on the money
PostPosted: Jan Fri 09, 2004 1:18 am
My friend runs a 805 hp n/a 540 in his street driven 68 camaro wich weighs around 3400 to 3500 and he ran a best of 9.85.......He threw 300 worth of bottle at it and went 9.18 @ 154 with very nasty wheel spin(about 100 feet out).....anyways I would say your right where you should be....
PostPosted: Jan Fri 09, 2004 9:53 pm
When these shops advertise the hp readings i have always thought that they were over stated.I have always used the moroso and chrysler slide rules for hp comparison.Which i worked out at 800 HP. My old 454 run 9.8@137 in the same car which weighed 3550 lbs and only crossing the line at 7300"still had more in it".With the old motor changing timing would affected mph and would go 3 mph faster at night compared to during the day.This engine will not respond too any tuning. THANKS FOR YOUR INPUT
PostPosted: Jan Sat 10, 2004 1:49 pm
What is a moroso and chrysler slide rule?????
 Post subject: RE-Ignition
PostPosted: Jan Sat 10, 2004 7:54 pm
The moroso slide rule is available in thier catalogue.As for the chysler it is a chart and you join the weight and mph together to get hp reading.I think i got it out of their power manual book.I have also seen it in some other smaller books that they have printed.Can go and ask my MOPAR obsess mate if he can find it.
PostPosted: Jan Sat 10, 2004 7:55 pm
PostPosted: Jan Sun 11, 2004 3:19 pm
I tried the weight and mph figure but it really wasn't anywhere close to my dyno sheets, but it is a good starting point for anyone....
PostPosted: Jan Tue 13, 2004 8:01 am
Well iam going te get a 16 volt step up box and close up spark plug gap.If the mph does not come up i will have to be happy with what mph i have.
PostPosted: Jan Wed 14, 2004 12:09 am
Nice, keep us posted on your results.....very interesting.
PostPosted: Jan Thu 15, 2004 9:48 pm
If you are gonna get an ignition system, spend the extra dollars and get a MSD Digital 7 Programmable. It will allow you plot you timing curve and help with the tire spin issue. It is also about 30% stronger in spark energy than the old 7-al's.
PostPosted: Jan Sat 17, 2004 2:04 pm
Does the digital-7 allow you yo launch at a desired timing and then advance it as you need it??????? That would be realy usefull......
Users browsing this forum: No registered users and 26 guests
