It is currently Nov Sat 21, 2026 5:19 am
Post new topic Reply to topic  [ 10 posts ]
 Post subject: NOS WITH ALKY
PostPosted: Jan Fri 28, 2005 8:28 am
WAS WONDERING IF ANYONE HAS ANY EXPERIENCE
WITH THIS TYPE OF SETUP??
LOOKING FOR A GOOD START POINT?
PostPosted: Jan Fri 28, 2005 8:41 am
Wow, I don't even have a clue to be honest with ya.. I know someone who might, I will call and write back after I hear from them...
PostPosted: Jan Fri 28, 2005 10:47 am
thanks kevin I APPRECIATE IT
PostPosted: Feb Fri 11, 2005 8:11 am
kevin did you ever talk to the person you were talking about
thanks tim
PostPosted: Feb Fri 11, 2005 9:08 am
Sorry Tim.. I will try him again today... :oops:
PostPosted: Feb Fri 11, 2005 10:47 am
thanks
ANTINORA TEAM RACING
79 MONTE CARLO
99 BOULTON RED
00 ANTINORA JR DRAGSTER
PostPosted: Feb Tue 15, 2005 10:49 am
I'm still trying Tim.... I think today though.... I missed his call yesterday...
PostPosted: Feb Wed 16, 2005 1:00 am
Tell us some more about your setup.
Are you running alky now and want to spray with alky also ?
I have some local guys that run alky injection and have tried to run the nitrous with alky also. They had some success but not the best.
I find it better to run gasoline/nitrous if alky is your primary fuel.
If your primary fuel is gasoline, its easiest to run gas/nitrous but there are gains to be had with alky/nitrous.
Any of the nitrous companies will give you a suggested jet spread with and of the above combinations.
Hope this helps, Hutch
PostPosted: Feb Wed 16, 2005 7:40 am
Thank you Hutch... I appreciate your input.....
PostPosted: Feb Wed 16, 2005 8:31 am
ok first thank you
my current set up is a 468 with enderle inj. on alky
canfield heads approx 14:1 comp. in a 1800 lb red
i need to pick up 3 to 4 tenths to make td fields
i would like to stay on alky & spray but i didnt know
if i should mix with gas or not. i kind of figured that was the best
way.(with gas) so i already started building another fuel cell for the gas
part. again thank you for any help!
TIM
79 MONTE CARLO
99 BOULTON RED
Users browsing this forum: No registered users and 2 guests
