It is currently Nov Wed 11, 2026 4:37 pm
Post new topic Reply to topic  [ 10 posts ]
PostPosted: Dec Fri 17, 2004 11:41 am
I AM CONVERTING FROM A REAR STEER TO A FRONT STEER BY INSTALLING A FLAMING RIVER RACK, MY QUESTION IS WHO'S STEERING ARMS DID YOU USE ? AND WHAT PROBLEMS IF ANY HAS ANYONE HAD WITH BUMP STEER AND OR DRIVEABILITY ON THE STREET CAUSE AFTER ALL, ALL THE CARS IN THE NATIONAL STREET CAR ASSOCIATION ARE DRIVEN ON THE STREET RIGHT !!! :lol: :lol: :lol:
THANKS FOR YOUR HELP
PostPosted: Dec Fri 17, 2004 11:54 am
I may be off base on this Phil. But if I remember right you just flip them from side to side.
PostPosted: Dec Fri 17, 2004 12:05 pm
THANKS RICK, WOULD A NOVA FALL IN THAT SAME BASE LINE ? I'M HOPPING SO.
PostPosted: Dec Fri 17, 2004 12:21 pm
Thats what I meant , For a nova or camaro. To put a rack in a mustang it's easier just to cut it off at the firewall :wink:
PostPosted: Dec Fri 17, 2004 12:33 pm
THANKS RICK
LOOKS LIKE I'M GOING TO HAVE A SHORT CHRISTMAS VACATION CAUSE IM NOT COMING OUT BUT TO SLEEP AND EAT TILL THE RACK IS INSTALLED
PostPosted: Dec Fri 17, 2004 2:05 pm
THANKS RICK
I agree with Rick on the steering arm thing.
Remember phil the key is to have the tie rod running as parrellel to the a-arm as possible to minimize the bump steer. In a perfect world the pivot points of the lower a-arm and the rack would be at the same width.
Remember I'm not far from you so If you need a hand let me know I can swing over. 8)
PostPosted: Dec Fri 17, 2004 2:22 pm
THANKS BOB, DID YOU GET MY EMAIL THAT I SENT YOU LAST NIGHT AND THIS MORNING ABOUT THE REAR END
PostPosted: Dec Fri 17, 2004 10:48 pm
Now that's what I call working together... :D
PostPosted: Dec Mon 20, 2004 3:55 pm
Don't know how far along you are on this Phil - but a buddy of mine just finished up on his rack conversion. He used Pinto spindles on his setup and cut down some of the width of the main crossmember. Rack ended up right in line with the steering arms. Did have to use spacers to set the rack height in relation to the steering arms. We've checked it and it's excellant on bump steer throughout the suspension travel.
I'm doing mine this winter with David Lemmonds Moly A-Arms, Wilwood rack and his billet steering arms (a little longer than the stock one flipped around). I think ideally you want the rack as close in line with the steering arms as you can get both vertically and horizontially.
PostPosted: Dec Mon 20, 2004 4:14 pm
THANKS JOHN
Users browsing this forum: No registered users and 470 guests
