It is currently Nov Tue 10, 2026 9:50 am
Post new topic Reply to topic  [ 13 posts ]
 Post subject: 1968 nova wiring harness
PostPosted: Jan Thu 08, 2009 7:36 pm
Looking for an aftermarket wiring harness for a 1968 nova. I see painless has a harness for 1969-1972 but no 1968.Is there any difference from 68 to 69 or can i get the 69 and install with no major modifications. Is there any other companies making harnesses for 1968 nova. Thanks for any and all replies. :mrgreen:
PostPosted: Jan Thu 08, 2009 10:39 pm
i wouldnt think there would be any difference in the years, i know the dashes are a little different but they all have the same components. i would give painless a call to be sure before you order if it were me.
PostPosted: Jan Fri 09, 2009 10:03 am
I know the 68 had the ignition in the I.P. as apposerd to the steering colume from 1969 on....
I would call then and ask what they have. Sorry, I haven't run into this as I just put a switch box in mine and just ran wires..
Actually, Monty came over with a friend and we all did it together...
PostPosted: Jan Fri 09, 2009 7:22 pm
They have the factory ones, and there is a difference.
WWW>Luttyschevy.com
PostPosted: Jan Fri 09, 2009 8:04 pm
Go Pitt.... 8)
PostPosted: Jan Fri 09, 2009 9:33 pm
thats right, its on the dash- forgot about that!
PostPosted: Jan Fri 09, 2009 9:35 pm
-jacob
PostPosted: Apr Sun 12, 2009 3:52 pm
Just installed the 67 camaro harness from painless and all the harness was the same except the plug that goes into the insturment cluster was different,By that i mean the pins were in different loactions in the plug. But the harness was a nice fit and the harness was long enough for a nova
PostPosted: Apr Sun 12, 2009 6:46 pm
Did you pull out the connectors and relocate them?? If so, how did that go??
PostPosted: Apr Mon 13, 2009 12:55 am
I'm just in the process of switching the pins in the plug. I have to find some info on the 68 nova plug. The painless wiring diagram tells what all the pins in the harness are for i just have to switch to the proper location for my application.Not a big deal just a little bit of time.
PostPosted: Apr Mon 13, 2009 8:25 am
PostPosted: Apr Mon 20, 2009 2:54 pm
Switch pins in plug for insturment cluster. Have to give a thumbs up to painless wiring, i received the wiring harness diagram in less than a day. It was no big deal to switch just used a paper clip to pop the locks on the terminals and switch into proper location.
PostPosted: Apr Mon 20, 2009 9:03 pm
8) Thanks for the heads up...
Users browsing this forum: No registered users and 355 guests
