It is currently Nov Wed 25, 2026 4:08 am
 Post subject: tons OF pARTS FOR sALE
PostPosted: Feb Tue 13, 2007 5:28 pm
MOSER 9" ALUMINUM SPOOL 35 SPLINE -NEW- $195.00
http://cgi.ebay.com/ebaymotors/MOSER...mZ190064540658
JOHN LANGER Pontiac Drag Racing T-Shirt -NEW- $14.95
http://cgi.ebay.com/JOHN-LANGER-Pont...QQcmdZViewItem
HOOTERS RACING Drag Racing T-Shirt SUGAN Top Sportsman PRO N/A -NEW- $17.95
http://cgi.ebay.com/HOOTERS-RACING-D...QQcmdZViewItem
WOLFE RACECRAFT Upper Control Arms -NEW- $195.00
http://cgi.ebay.com/ebaymotors/WOLFE...mZ190072081977
70-72 NOVA STUFF FOR SALE:
(1)RF drum brake knuckle (wheel bearing housing) USED $50
(1)LF drum brake knuckle (wheel bearing housing) USED $50
(2) Front Hubs - Drum with stock 3/8 studs - USED $20. pair
(2) Front Hubs - Drum with MOROSO 7/16 extended studs - USED $40. pair
(2) Spindle arms - USED $20. pair
(1) Center link - Fat - USED $25.
(2 pairs) Stock tie rods with sleaves Left and Right sides - USED $20. a side
MOROSO BBC Clear Aluminum Anoidized Valve covers (ran them for 1/2
season-like new) $50.
MOROSO BBC Aluminum Gold Anodized Valve Covers $30
TIRES:
29x10-15 HOOSIER SLICKS -Used- Very Few Run's on them
$175 Pair Pick up only
30 X 12.50 -15 M/T ET STREET DOT (4 PASSES)
$100. ONE TIRE ONLY Used PICK UP ONLY
30x9-15 FIRESONE FIREWAWK SLICKS
about 10 years old, worked awsome when I ran them, pleanty of life left. Great for a Nostalgia car.
$100. pair PICK UP ONLY
30 x 9 -15 HOOSIER RADIAL SLICKS
Good condition, 4/32" left in the holes on these tires.
Switched to a D.O.T. Tire, thats why there for sale.
$150. PAIR - PICK UP ONLY
WELD DRAGLITES 15 x 8 - 5.5 Backspace 5 Lug 4.5 / 4.75 Bolt Pattern
drilled for screws - Used
TH400 Chevy trans. short tail, TCI reverse manual valve body, alto red clutches, good 34 element sprag
could use a freshening. $400 PICK UP ONLY
TH400 Chevy trans. short tail, foward shift, shift hard, works great $350 Pick up only
BBC 4.0" 454 Cast CRANK STD./STD. Came out of my 468" motor $175. Pick up only
JE Custom Pistons (set of 10) NEW in BOX
555" BBC
with JE rings, Wrist Pins, and Locks 4.560" Bore
for 6.385 Rod length
for 4.250 stroke
Compression Distance 1.270 .990" pin
Ring Package: 1/16 1/16 3/16
$700. Complete!
A BUNCH OF OTHER STUFF ON E-BAY :
http://stores.ebay.com/Lethal-Dealz_...QQftidZ2QQtZkm
+ S&H (except for pick up only parts) Located just outside of N.E. Philadelphia, PA
E-MAIL ME: SST1774@msn.com
PayPal and Money Orders accepted
100 % Positive Feedback
PostPosted: Feb Tue 13, 2007 6:11 pm
Boy, your weren't kidding about the lots part... :lol:
PostPosted: Feb Sat 17, 2007 4:23 pm
You running NMCA this year Kevin? Saw you walking around at Maple Grove last year and I heard NPS is no more in NSCA.
Updated List !!
PostPosted: Feb Sat 17, 2007 6:26 pm
Yep, looking forward to Bradenton... We were in the neighborhood that weekend so we stopped in to check it out...
PostPosted: Feb Tue 20, 2007 11:14 am
MOROSO ULTRA 40 Race wire set SBC Plug wires 73600 -NEW- $129.95
http://cgi.ebay.com/ebaymotors/MOROS...mZ190015865393
FLUIDAMPR 454 HARMONIC BALANCER BIG BLOCK BBC EXT. balanced 2 available -USED- $199.95
RARE EDELBROCK TM1 SBC Intake Small Block Chevy -USED- $59.95
http://cgi.ebay.com/ebaymotors/RARE-... emZ8066557590
WELDON 16000-A Fuel Pump -NEW- $1300. (sells for $1450)
Flows 7 GPM, Rated for 100 PSI -16 inlet -12 outlet ports - Good for 4000 HorsePower
MOROSO VACUUM PUMP Bracket -NEW- $39.95
http://cgi.ebay.com/ebaymotors/MOROS...mZ190071918149
WILWOOD DISC BRAKES Small Ford REAR Dynalite Drag Race -NEW- $449.95
http://cgi.ebay.com/ebaymotors/WILWO...mZ190072078167
MSD STARTER - SBC & BBC (PAYS NMCA CONTINGENCY)
NEW - $199.95
http://cgi.ebay.com/ebaymotors/ws/eB...1151832&rd=1,1
MSD 7AL2 PLUS
NEW $535.00
MSD DIGITAL MULTI-STEP RETARD #8975
NEW $149.95
(4) Front brake drums - USED $10. each
(1) Center Link - Thin - USED $25.
(1 pair) Muli-Leaf springs 68-74 NOVA with Competition Engineering Aluminum spring eye bushings installed. B.O.
COMPETITION ENGINEERING J-Bolt Traction Bars - Used- Painted Black B.O.
TIRES:
28x11.5-15 HOOSIER QUICK TIME PRO'S DOT
They had them on a car and it rubbed on the inside so they took them off. Street driven around the block only. Excellent condition.
$250. Pair Used PICK UP ONLY
drilled for screws - Used $225. PAIR
Cervini Fiberglass hood - Used
Pin-on style (with dzus pins installed)
5.5" cowl goes to the windshield
painted white, has some chips and cracks in the paint.
fits 87-93 Ford Mustangs $200 obo PICK UP ONLY
CERVINI'S FIBERGLASS HATCH NEW !!!!
Fits 1979-1993 FORD Mustang Hatchback
Bolt-on - in white gelcoat PART# 351 ($499. from Cervini)
You can use the factory glass and all of the components. Very nice design.
$250. obo PICK UP ONLY
GLASSTEK 87-93 MUSTANG HOOD
6" Cowl Induction Pin On (Scoop to Windshield)
Fiberglass - Brand NEW $250. PICK UP ONLY
12 Bolt Leaf spring rear - Fits 68-74 Nova, 67-69 Camaro/Firebird (stock spring location) Strange Spool, Strange Axles, Strange C-Clip eliminators, 4.10 Strange Gears, 1/2" Studs, LPW Aluminum cover with backbrace rod, Tubes welded, for multi or mono leafs. Reinforced mounting pads. Less brake calipers and rotors (has Strange caliper mounts installed). $1500. OBO PICK UP ONLY
555" BBC
for 4.250 stroke
$700. Complete!
I'm INTERESTED in a Few of your Parts?Please either email me or give me a call @ 231 462 9623
THANKS
Greg
Users browsing this forum: No registered users and 4 guests
