It is currently Aug Wed 19, 2026 2:28 pm
Post new topic Reply to topic  [ 10 posts ]
 Post subject: cage question
PostPosted: Jan Sat 27, 2007 12:45 pm
ok, i did a ladder bar backhalf on my nova.
i have to change the bars on the back of the main hoop of the cage to attach it to the new rear frame rails.
should i just run the traditional two rear bars to the frame rails and a X to the shock crossmember or should i have a rear hoop bent up like i see some of the newer cars have ?
is one way better than the other?
PostPosted: Jan Sat 27, 2007 1:18 pm
There's really no difference. The bars connecting to the shock crossmember are what's important. The bars going to the back of the car are only there to hold up the back of the car.
PostPosted: Jan Sat 27, 2007 1:22 pm
so should i run two parallel bars to the shock crossmember or should i run them as a X ?
PostPosted: Jan Sat 27, 2007 1:45 pm
Anytime you can make a triangle ( X ) it will be stronger than a straight tube.
PostPosted: Jan Sat 27, 2007 1:56 pm
thats what i was thinking...
i really like the way some of these newer cars look with the hoop at the back of the cage. but that would cost more since i would have to buy more tubing and then i would have to have it bent. it would set me back about 2 more weeks. im trying to get it all put together asap but at the same time i am questioning if i am going to be happy with doing the bars this way, tough choices...
PostPosted: Jan Sat 27, 2007 4:32 pm
or do yall think i am putting to much emphasis on something that isnt really important?
PostPosted: Jan Sun 28, 2007 11:08 am
i will post some pics next week...
PostPosted: Jan Sun 28, 2007 11:28 am
It's all what you want. Functionally, it will work either way. My car has a hoop just because it made it easier to mount the body and the bars don't show as much looking in the back window.
PostPosted: Jan Sun 28, 2007 11:36 am
could you send me few pics rick?
PostPosted: Jan Sun 28, 2007 8:40 pm
Hey jacob my car has a rear hoop, and it's all x braced in check out that web sit for some pic's
Users browsing this forum: No registered users and 57 guests
