It is currently Nov Sun 29, 2026 6:03 pm
 Post subject: Vac pump Question
PostPosted: Dec Sun 03, 2006 7:28 pm
I am putting a Moroso Vacuum pump on my car & need to know which fitting is the inlet & which is the outlet. I went to Moroso's web site, but what I downloaded does not look right.
if you are looking @ the pulley from the front there is a V @ the top of the pump where the fittings stick out. is the left the IN or is the Right the IN???
thanks guys.
PostPosted: Dec Sun 03, 2006 7:41 pm
DAH....... the one that sucks is the inlet...... the one that blows the outlet :P
www.yourwaynetwork.com
**Check out my new site**
www.SALEENSpeedLabTV.com
PostPosted: Dec Sun 03, 2006 7:42 pm
I'll PM ya Ricks cell if ya want it
PostPosted: Dec Sun 03, 2006 8:16 pm
If your pump has the Moroso part number and Moroso name on it, the inlet fitting is to the right as you are looking at it from the front assuming you are turning it clockwise from the front. A way to double check this is the inlet to the outlet will be the farthest apart in a clockwise rotation. Hope this makes sense and helps...
PostPosted: Dec Sun 03, 2006 9:03 pm
thanks Jimmy, your a BIG help. LOL.
thanks Kevin, that helps out. Jimmy take notes from Kevin would you.
PostPosted: Dec Mon 04, 2006 8:31 am
Users browsing this forum: Majestic-12 [Bot] and 580 guests
