It is currently Nov Mon 16, 2026 10:48 pm
PostPosted: Mar Fri 17, 2006 9:41 am
Ok, here is the revised draft of the rules. If you have any input, please post it here as they need some help with the rules. I want to make it clear that these rules listed are for REVIEW and people need to take comprimise on things as they WILL NOT make the rules to fit only 2 or 3 cars. For right now the sponsors are putting together 4 classes being Outlaw 10.5, Limited 10.5, All Motor and Drag Radial. Now the opportunity for a True Street class has not been exhausted, there is an opportunity for this class if a sponsor can be found. I've listed the rules for this class as well, but right now it's not going to happen if a sponsor can not be found. If you know of someone interested in the class, please email me at underdog@gofastzone.com for more information.
It appears the Race dates will be on the second Friday night of each month, gate will open at 5:00pm, start 1st round of qualifying at 7pm.
AllSpeed Performance / Steve Morris Racing Engines Heads-Up Racing
Presented by Holley/Lunati
All classes are designed for door cars only.
All cars must pass class rules and General Regulation IHRA rules.
Entry Fee for all classes $50
Payouts as Follow:
Outlaw- Limited- All Motor- Drag Radial
Winner $1500 $1200 $800 $800
Runner-Up $500 $500 $400 $400
Semi $250 $250 $200 $200
¼’s $50 $50 $50 $50
RULES
Outlaw 10.5
10.5 W tires OK any size DOT OK
.400 Pro Tree
8 Car qualified field
Sportsman ladder
Any Chassis OK
3000lbs base weight Min
Add 100 lbs for clutch cars
Add 100 lbs for twin turbo cars
Add 100 lbs for full tube or square chassis
Deduct 100 lbs for BB with nitrous
Deduct 300 lbs for SB with nitrous
Mufflers required
Limited 10.5
10.5 slicks (NO W’s)
.400 Pro Tree
Sportsman ladder
DOT tire limited to 12in wide 30in tall
No full chassis cars allowed (Back half cars OK)
3200 lbs minimum weight
Add 100 lbs for single turbo
Add 200 lbs for twin turbo
Deduct 200 lbs for SB with nitrous
Deduct 100 lbs for stock OEM rear suspension
Mufflers required
Wheelie bars allowed
All Motor
.400 Pro Tree
Sportsman ladder
No Power adders
Auto Trans or Clutch Assisted Stick Only
All cars must be shifted manually (No Electric or air shifters)
Maximum tire 29.5 x 10.5 (No W’s allowed) Drag Radials Ok they must meet slick size spec
Single 4 barrel carb or single 4 barrel throttle body (EFI) - Must be conven square pattern design
Cast intake only (No sheet metal intakes)
Ladder bar, 4 link, and stock style suspension allowed
Stock frame rail from firewall forward (NO tube chassis front end)
Stock appearing interior, including TWO front seats
Small block minimum weight 2900 lbs
Big block minimum weight 3400 lbs
Add 200 lbs for clutch cars
Mufflers required
Drag Radial
.400 Pro Tree – 8 Car Qualified Field
Tires - Radial tire maximum 12" measured tread width
Stock Style Suspension Allowed - No Wheelie Bars allowed (Direct bolt on replacement parts or added bolt-ons such as slapper bars OK) .
Car must have stock rear frame rails (notching OK for tire clearance).
Any type of power adder or adders allowed
Weights - 3,300 lb. base weight
Deduct 100 lbs. for big block with nitrous
Deduct 400 lbs. for small block with nitrous
Add 100 lbs. for Twin Turbo's
Stock Appearing Interior, Including TWO Front Seats
Must use Mufflers
Not on the program yet, Looking for sponsorship!!!
True Street
.400 Pro Tree
16 car qualified field
Sportsman ladder
Class will run off a 10.00 index with no breakout allowed
10.5 (NO W’s) slick or up to 12 inch DOT tire allowed
Stock Suspension, 4 link suspension or ladder bar
(Inboard spring kits allowed, anti sway bars allowed)
Bolt on aftermarket suspension pieces bolting into original location allowed
Fender well modifications for tire clearance allowed
Car must be stock appearing
Any power adder OK
Front wheel drive 2400 lbs min
4 cyl 2800 lbs min
6 cyl 2900 lbs min
Small block 3000 lbs min
Big block 3200 lbs min
PostPosted: Mar Fri 17, 2006 10:30 am
I don't see the red car weight break rule there anywhere.... :shock:
PostPosted: Mar Sat 18, 2006 8:52 am
and there wont be one!
Chuck L.
Global Motorsports
PostPosted: Mar Sat 18, 2006 9:40 am
Now why ya gotta be like that Chuck..... 8)
Users browsing this forum: No registered users and 564 guests
