It is currently Sep Sun 27, 2026 12:18 pm
 Post subject: if i have
PostPosted: Oct Tue 06, 2009 5:07 pm
a 4.75 crank and a 10.2 deck height block and a piston that has a 1.12 CH what length rod do i need? 6.600 or 6.700?
PostPosted: Oct Tue 06, 2009 9:09 pm
10.2 block subtract 2.375 for the stroke is 7.825.
7.825 subtract 1.12 CH is 6.705
If it is a aluminum rod you need to be say .020 in the hole, so....
6.705 subtract 0.020 is 6.685 long rod.
Hope this helps.
PostPosted: Oct Wed 07, 2009 9:46 am
Hope this helps.
SHOW OFF !! :lol:
PostPosted: Oct Wed 07, 2009 10:49 am
:wink:
Done it once or twice..... :lol: :lol: :lol:
PostPosted: Oct Wed 07, 2009 3:15 pm
you got some 6.685 rods laying around :lol:
PostPosted: Oct Wed 07, 2009 3:16 pm
im not going to run a aluminum rod, im just gonna use a h beam or something that is off the shelf. the piston recomended a 6.600 rod and i knew that wasnt rite.
PostPosted: Oct Wed 07, 2009 9:19 pm
As a matter fo fact, I do.... GRP's
PostPosted: Oct Wed 07, 2009 9:21 pm
So you may get away with a 6.700 long rod then. I would talk to your piston maufacturer though...
PostPosted: Oct Thu 08, 2009 7:39 am
i called world products (mahle makes this piston for them for there crate engine) he gave me the part number for the rod they use. its a 6.7
PostPosted: Oct Thu 08, 2009 12:08 pm
What head gaskets???
Spray???
RPM????
Chevy head or big chief???
Carfull when chosing your cam since you are going with a off the shelf piston...
PostPosted: Oct Thu 08, 2009 8:03 pm
my block has O rings so im not really sure what head gasket to use. it will not see any nitrous, the piston specs are:
Bore (In) 4.600
Stroke (In) 4.750
Rod (In) 6.600
Pin .990
Comp Hght 1.120
Weight 528g
C/R @ 0 deck 10.4:1
Crown -6cc
i am using a conventional head. this isnt going to be a max effort motor, i want it to be pump gas friendly also
Users browsing this forum: No registered users and 23 guests
